That lock strip tool was really nice. Cheap too, I can imagine it would a lot more work to install it with the levers.Man I wish I had that lockstrip tool last weekend. I got it back in solo as well, but it took me a while. I tried the gasket on the frame first, but couldn’t get my kungfu to get that way. Funny enough I had the same levers. They got the lock strip back in, but it fought me all the way.
Don't use ic2000 for installing glass. Let's say you stretched a fj40 tub 10." Now you need hard top windows that are 10" longer as well. First you cut custom glass that is 10" longer. Now you also need weatherstripping for the side glass that is 10" longer. So to do that you order 2 pieces per glass of side glass weatherstripping. One piece you will cut out 2 10" pieces from top and bottom of the weatherstripping. Then you will cut the other weatherstripping at top and bottom and use ic2000 to graft or glue the 10" sections you cut out from the other piece to make one 10" longer window weatherstripping. Once the ic2000 is dry you can install the glass into the weatherstripping, then install the glass with weatherstripping into the hard top.Someone recommended this product to me for bonding weather-stripping together, and in my experience works better than the 3M product above. Creates a factory like bond.
IC-2000 | Rubber-toughened CA - https://bsi-inc.com/hobby/ic_2000.html
Weatherstripping adhesive is for installing door jamb weatherstripping to a door frame. For windshields glass companies use a windshield adhesive of some type that seperate from those I've mentioned. I don't know what it's called off the top of my head. However for fj40s I was under the impression that no adhesive was to be used on any glass installing and that includes the windshields.
I believe he was going to use it to bond the cut in the gasket. Sor gaskets now come unbonded. Previous versions were bonded together to make a loop.
Oh ok I just wanted to make sure someone didn't superglue something they shouldn't.@tornadoalleycruiser is tracking correctly. I was under the impression that I had to graft the ends of my gasket together which is what I planned to use the IC2000 for. It turned out that my gasket didn’t need it, so I did not have a use for it. In the end I did not need the IC2000.
Looks like it’s coming along great! You did a good job keeping the engine bay cleanAfter rummaging through the heater hose section of three parts stores I found a hose to finish plumbing the heater lines. I spent the rest of the day finishing off a number of little things to include putting the final touches on the harness and relay/fuse boxes under the hood.
I have a few more things to take care of tonight and if it goes well I should be able to take it for a test drive tomorrow.
Best of luck, been a long time coming for sure.
