mongoose2231
Supporting Vendor
I've had mine for 2 years now, barely got anything done on it. Some of you guys out there buy these trucks and within weeks tear them apart and put them back together. That is impressive work right there.
Shawn, received your email through 'mud, but the mud-linked return address is bad. Update your mud profile w/ a current email and ping me again.
PS. You are a masochist. Pulling and installing the engine without removing core support crossbar, condensor, grill? Hardcore.
Still idles a little rougher than I like but seems like I've run across comments referring to the '60 Stumble'.
Nice! Glad you're enjoying it. I think your cargo panels are the first I've seen without 6x9's cut into them. So you have the sub and two door speakers in the front? I saw that you said it sounded good so curious.
...what's the story behind the molecule in your avatar?
The stumble is caused by being 50 RPM lean of the smooth idle setting.
Dopamine. The neurotransmitter involved in all pleasurable experience... and addictions.
Huh...Dopamine, you say? Addictive? Maybe that explains the sudden urge to eat my computer screen...
Finally got the cargo area put back together after sound system upgrade. Feels good. Sounds good. I took the opportunity to clean out the bottom of the quarter panels and do a little Por-15 treatment.
The original carpet was oil stained and rotten. The diamond plate rubber turned out ok, but I would rather have used original carpet. Couldn't find a piece in good shape that wasn't a million dollars.
Build is looking great. Once you start there is always something else, especially while reading this forum. Interested in where you got the rubber mat from and what you used for padding? Thanks.
