The LX450 replacement (beater DD and family hauler) (1 Viewer)
Central NY
Website
www.mcboost.com
I picked this up a couple months ago after randomly searching and finding one just over an hour away, I was off to take a look with cash in hand.
When I got it:
It needed a bunch of hatch work (as expected) and had a few things I fixed along the way. The front shocks were leaking so the suspension overhaul recently took place.
How it sits so far:
I plan on picking up new wheels and tires next spring. I'll wear these out first over the winter. I still need to replace the rear A/C lines I could not get apart, but I do have that side interior taken apart already.
Below is my progress thus far (and how I keep track of things:
DONE/FIXED/BOUGHT
  • 2018 - 07-13 - Bought - 2006 Toyota Sequoia SR5 and brought it home.
  • 2018 - 07/13 - Bought - OEM replacement parts: Hatch latch, door handle and front blower motor.
  • 2018 - 07/15 - Fixed - Polished headlights, fixed some chips and scratches
  • 2018 - 07/17 - Bought - OEM set of floor mats, rear plate light lenses & gaskets.
  • 2018 - 07/18 - Fixed - Blower motor and installed the new latch.
  • 2018 - 07/19 - Fixed - Passenger door handle was loose, Bolt fell out, found, threadlocked & fixed.
  • 2018 - 07/20 - Mod - Disabled the daytime running lights.
  • 2018 - 07/27 - Fixed - Bought and installed new RSE wireless headphones
  • 2018 - 07/30 - Fixed - Fan clutch replaced
  • 2018 - 08/04 - Fixed - Replaced thermostat, refilled coolant and bled the system fully.
  • 2018 - 08/09 - Bought - Complete rear window regulator and rails.
  • 2018 - 08/12 - TRIED - To separate the rear A/C connection below HVAC box.
  • 2018 - 08/15 - Bought: both NEW rear A/C lines that are not coming apart.
  • 2018 - 09/02 - Fixed: (Started!) Replacing the rear window regulator and rails... window sashes broken
  • 2018 - 09/03 - FOUND: A local friend had a hatch and sold it to me complete for $120.
  • 2018 - 09/03 - Fixed: The hatch window regulator and window wiper.
  • 2018 - 09/12 - Bought: The lift, shocks, rad, washer res, diff drop
  • 2018 - 09/14 - Mod: Rear spoiler mounted and wired.
  • 2018 - 09/18 - Fixed: Homelink module/broken button.
  • 2018 - 09/26 - Fixed: Replaced radiator and front sight glass leaking AC line
  • 2018 - 09/27 - Mod/Fixed: Replaced the front struts, rear shocks and springs, and sway bars
  • 2018 - 12/04 - Fixed: Replaced the two rear A/C lines (not really fixed though)
  • 2019 - 06/21 - REALLY fixed: A/C fixed. New rear line was loose at a connection.
  • 2019 - 07/11 - Mod: (5) Wheels ordered.
  • 2019 - 07/21 - Mod: (4) 285/70 17s and GTR V3.0 led bulbs ordered.
  • 2019 - 07/21 - Fixed: Installed a nicer skid plate after it was powder coated
  • 2019 - 07/27 - Mod: Tires mounted on the new wheels and wheels installed.
  • 2019 - 07/29 - Mod: New wheels and tires on.
  • 2019 - 08/01 - Mod: Installed GTR Lighting LEDs
  • 2019 - 09/03 - Fixed: Repainted the speaker grills (looked a bit rusty)
  • 2019 - 11/24 - Fixed: Cut in and replaced the rear wheel well metal where is always rots.
  • 2020 - 07/18 - Road trip: Towed the MR2 home from a painter out of state.
  • 2020 - 09/22 - Fixed: Shift Solenoid E issue.
  • 2021 - 07/31 - Fixed: Upgraded all brakes to slotted and vented powerstop (red fronts) plue calipers front and rear
  • 2021 - 08/04 - Mod: Painted the power stop rear calipers with red epoxy to match the fronts.
  • 2021 - 08/05 - Bought: The tire for the spare aftermarket wheel
  • 2021 - 08/10 - Fixed: The TPMS light is finally off. Yes!!
  • 2021 - 08/15 - Mod: Replaced the front door blown woofers with aftermarket and it does very well now. Tweeters next, then a real sub.
  • 2021 - 10/28 - Mod: yellow laminx-ed the fogs and painted the silver moulding trim on one side black
  • 2021 - 11/13 - Mod: Plasti-dipped the SR5 and rear emblems.
  • 2022 - 06/04 - Mod (and cleaned!) Installed a NICE set of TRD 4X4 stickers. Clean, polished and waxed FINALLY.
  • 2022 - 08/24 - Fixed: Timing belt/WP/etc, plus new valve cover gaskets done and picked up.
  • 2022 - 12/25 - Ordered - Amp power wiring, RCAs and line level converter with remote adjustment
  • 2023 - 01/29 - Fixed: Rear plate light wiring
  • 2023 - 01/30 - Ordered: OEM hatch plate trim and latch cable, HD metal latch handle and LED plate panel lights
  • 2023 - 02/15 - Fixed: all plate trim items fixed! New LED panel lights and all. No more broken tabs.
  • 2023 - 04/03 - Mod: installed camry LED reflector lights.
  • 2023 - 05/29 - Fixed: programmed and added a second keyless entry remote for the second set of keys
  • 2023 - 06/09 - Mod: Installed the new black front headlights, corners and new LED projectors
  • 2023 - 06/14 - Bought: GX460 and 4runner rotors for the brake upgrade this needed
  • 2023 - 06/19 - Bought: SS front brake lines
Nice rig.. any updates?
Thanks! Not quite yet. I still need to replace the rear A/C lines next week, put on the lamp gaurds for the headlights/fogs/etc and give it one more good cleaning before winter. Wheels and tires are planned in the spring (I want to wear out the tires more as they are almost new).
I have been busy with my other "toy" projects which will end soon as winter is approaching.
What's life span of these? How is the coverage for high beams, still have a dead spot in the front with high beam on?
no idea, but should be longer than a old school bulb. they are built quite well. No, the high beams are serious. Although once I figure out the fog light mod, that will make them even better.
welcome to the sequoia club
It's been a great truck with the only issue being a problem with the E shift Solenoid. It was fixed pretty quickly though. This summer I will be installing a custom fiberglass sub enclosure in that goofy compartment and see what that turns into (I used to install IASCA and dB drag custom systems).
Here is a bit of a photo diary to catch everyone up.
Low beam on the road:
High beam:
"new" skid plate power coated:
Door grills repainted:
Rear wheel well rot replaced:
Towed my MR2 home like a CHAMP (only 2MPG less than normal) from out of state:
High beam:
What was the eshift issue? Did you have any codes for it?
Yeah, I forgot what the code was tho..
Why do you ask? I may be able to look back for it if you are troubleshooting something. LMK!
ah, not at all what my symptoms where. Mine was a CEL with normal operation, but the next day it would barely drive and seemed almost like speed sensor issue with traction control.
Quite a while since my last update.
I did replace the front blown speakers and have to say I am impressed with the amount of bass and power they will take. For $59, I am very happy.
cheap here:
I just chopped up the old ones to use their metal bezel as a mount and screwed the new speaker into that metal bezel. Still 7" and 2ohm. They work GREAT.
Replaced the front and rear brakes with power stops. front where powder coated red, the rears I epoxy painted to match. New x drilled and slotted, zinc plated rotors front and rear.
Match is quite good and it definitely stops much better.
