- Thread starter
- #361
No pics?
Mounted the light upside down, and on the "interior" of the bull bar.
Many washers were used in the mounting of this creation lol
ran the wires behind the grille and back over to where the battery was
No pics?
Did you apply RTV or silicone to the ends of the lightbar and properly tighten all the allen screws on the front? Most of these chinese lightbars fail due to water intrusion.View attachment 3153666
not yetDid you apply RTV or silicone to the ends of the lightbar and properly tighten all the allen screws on the front? Most of these chinese lightbars fail due to water intrusion.
I have the same issue with one rear door, thats a good find about how to fix it.mmm, also discovered today that neither of the rear doors lock when using the power lock system.
Found this thread:
Will likely be ordering these at some point:![]()
Power Door Lock Problem - Driver Door
forum.ih8mud.com
FJ80 - FZJ80 Door lock motor
FJ80 - FZJ80 Door lock motor If your doors no longer lock and unlock this is likely the culprit, this or the arm is broken. Making a fix for that now.. This is the 20mm long shaft motor a replacement for the oem motor. Tin the electrical ends an shove into the motor for electrical connection...solvefunction.com
I think the only event till next summer is the Christmas party. I don't think a lot of wheeling happens at that event.ruminations:
debating if there are any more trips planned out here before the years end.
Considering pulling the 1fz-fe out, and doing the headgasket in my garage + cleaning up the engine bay.
Would likely consider a new engine hardness as well, or at least fixing up a good number of the connectors.
New distributor would be on tap as well, as the PO slathered this one with large amounts of RTV
I see that the firewall insulation did not fare well with all of the moisture at windrock.
If I had the motor out, I would likely pull the whole dash apart, and remove that unpainted strut, remove all of the rust, and then paint it.
but first things first will be getting a new windshield.
I have concluded that the cruiser would not fit in the garage without significant work.
I am unfortunately have obligations that weekendI think the only event till next summer is the Christmas party. I don't think a lot of wheeling happens at that event.
SamesiesI am unfortunately have obligations that weekend![]()
Its starting to be a common theme here on the forum. Im also doing it too.but also you know, these "cheap" LS powered vehicles are on craigslist O_O
yeah, im pretty torn about it.Its starting to be a common theme here on the forum. Im also doing it too.
If your gonna talk about it, you gotta show picslittle brother stopped by since he is in town for thanksgiving, we got halfway through the final steering knuckle / axle rebuild, after this, all will have been gone through.
attached is a pic of the new knuckle studs I though I had:If your gonna talk about it, you gotta show pics![]()
I see nothing lolattached is a pic of the new knuckle studs I though I had:
I see nothing lol
