The front of my A/c Compressor started leaking is this worth fixing or just buy new?
My a/c worked great last summer then I went to click it on this year and nothing, so I threw a little freon in the system and it is leaking from the front under the clutch somewhere. I saw there is o-ring kits is this something that can be changed quickly and fairly painlessly or should I just throw down for a new pump? Is there someowhere that will reseal an a/c compressor? I'm located in arizona so if there was somewhere here that would be even more helpful,
Thanks
The compressor front seal is not expensive and is easy to replace, but you need a special puller for the clutch.
One idea is to remove the compressor and take it to an A/C shop for replacing the seal. But you will need to visit a friendly shop, 'cause its like taking raw hamburger and a bun to a diner and asking the cook to make you a burger.
I recommend you go to a A/C repair shop for a quote on replacing vs. repairing.
Mike's point is accurate, but if you follow that logic, there's lots of seals to replace on the system, so I wouldn't go too crazy. The compressor seal is the biggest problem and failure area after the compressor has been sitting for some time.
Good luck,
Rick
Any Ideas for finding a decent shop that would do that? I'm in phoenix if anyone knows a place that could help? I really just need to get it through one more summer so I don't want to spend a ton if not needed.
I have the perfect shop for you. I just bought a new compressor from them and they shipped it to me. They beat the price of my local parts shop by $150. They will help you with any questions. Super nice people.
Cool Stream in Tucson, AZ
coolstreamac.com
520-918-3604
Talk to Rex and he is also a fellow mudder, which is very cool!
I have a good used one I will let go for cheap. PM me if you are interested.
Dynosoar:zilla:
