I have heard several things about locked hubs and shifting into and out of 4WD in a stock FJ40/43. Hoping I can get clarification.
I understand it is good to drive somewhat regularly in 4WD to keep everything turning and oiled. Makes sense. It is also occasionally a good idea to lock the hubs and drive if you aren't getting into an 4WD situation (wet or snowy roads or gravel). I assume this is correct.
I am primarily curious about shifting into and out of 2H, 4H and 4L. Is it OK to shift from 2H to 4H (assuming the hubs are locked) on the fly? Perhaps in neutral but with the wheels turning, say on a highway or road where there may be occasional ice and snow? I was driving through Oregon and was told to keep the hubs locked and to shift in and out of 4H as needed.
I believe it is a must to be stopped and in neutral to shift into or out of 4L.
Thank you for corrections and confirmations.
