The Dirty Pig From Paris
I ripped all the column shift/ vacuum transfer case stuff out today. I understand why people hate it. I also removed the intake and exhaust manifolds and exhaust. I will be using the intake on the 2F with either a header if I find a good used one or with the 2F exhaust manifold.
The engine is just mounts away from coming out.
I got a double Carden front shaft from a ‘81-‘84 FJ60, which according to the recipe card for putting a spacer H42 or H55F in a 55 needs to be lengthened 2.5”
Is there any reason I can’t just use two longfield driveshaft spacers, one on each end?
I realize it’s not as good as having the shaft lengthened by a shop, but the local driveshaft shop will probably be $300 to do it, and it is only the front shaft.
You should not need a DC shaft for one. The shaft is plenty long to work with regular.
If you want to dig through my driveshaft stash I’ll be I have one that length. If not I know I have some like new ones longer and having one cut down is cheap
Not sure on the spacer Idea.
The only reason I got a double Carden shaft is because of the length and I know it’s 2.5” too short.
Do you think a stock ‘85-‘87 shaft will work without being cut down?
I’ll definitely take you up on digging through the shaft stash next time I’m there.
@cruiserinsanity If you add two of those spacers you're going to increase the operating angle of the u-joints, which will cause them to wear more quickly. The DC joints also make the angles goofy on a stock truck. You'd ideally want the pinion flange at zero degrees to the u-joint connected to it - tipped up in other words. You may get there with caster shims if the shims are in the right way, but then you have to watch your caster angle. My shims want to go one way for better caster but go the other way for better u-joint angle with my DC shaft so I have to compromise. A "regular" driveshaft with a single u-joint at each end makes life a lot easier for stock or small-lift applications - just parallel the t-case and diff flanges. One other thing to check is if a "regular" driveshaft will clear the crossmember. I'm pretty sure that's the only reason Toyota stuck the DC ones on the early 60s, it goes a couple inches horizontally at the DC joint before angling downward, which gives it enough room to clear. When they changed the transmission & crossmember in 84/85 the front t-case flange wasn't buried so far behind the crossmember and they could use a regular shaft.
Do some math to see what you truly need. Measure the straight line distance between the bottom edge of the flanges, then measure the heigh difference between the bottom edge of the flanges. Set your driveshaft on the floor and mock it up to the same dimensions. Are the slip joint splines close to showing? If you mock-rotate it do the yokes bind? If not, you're good.
We got a shop here in Denver who does really good driveshaft work at reasonable prices, it's sad that isn't the case everywhere. My guy would retube that thing to add 2" for probably $80-100 and that would include balancing & some spray paint to make it look purdy. Every time I bring him a busted driveshaft he says "did you at least have fun?"
(And yes, I'll check for that flywheel this weekend)
We needs mo pics of dis Dirtay French 🐷🐖👈🧁😳😲😉🙂🧐🤔🤣🤣🤣🤣🤣
Unfortunately I do not have any more pictures of the marvelous machine, and currently a tropical storm is passing overhead so no new photos will be taken soon.
I can absolutely bore everyone with mundane plans though.
I will be going to Arkansas for a family trip next weekend. While I'm up there, I will be picking up some FJ60 rear axles for cheap. After I get them, I will be assembling the axles for the Dirty Pig.
Fj60 rear with 3:70s and FJ40 disc front with 3:70s. I will be running spacers on the front to make up for the additional width of the rear, unless I can find someone local to cut down a FJ60 rear axle to Fj40 width for a reasonable amount of money, like @J Mack did for Pumpkin Spice, but that probably will not happen.
I did pick up some later hubcaps from @Pigeaten in the classifieds, and some extra reverse lights.
One thing that bugs me about this truck is the 1/4" thick bondo on the driver's fender. The fender doesn't appear to be bashed up, just skimmed with bondo one of the four times it was painted. I can have it sandblasted for very cheap/ possibly free, and I'm probably going to do that with both fenders.
But then I'll need to paint them, and then they won't match the rest of the truck. The doors have been replaced and are black but are red underneath the black. So I will probably end up paintinh the lower 1/2 of the truck eventually and leave all the white sections alone, so it will be a halfa$$ spray painted partial patina truck.
If it was all faded evenly, I would leave it alone, but the bondo and contrasting doors bug me, and I have to paint the rockers anyway as they're just primed.
I definitely will be painting the roof, it has no paint on it and I don't want it to rust away.
Any of that, if it happens, will be done after I have it running and driving.
I also got a Minitruck PS box from @mesa man !
It looks great and power steering will be a great addition.
You got a little piece of my “Clementine”
In your “Dirty Pig” now! Cool it worked out
For both of us! Thanks!
I made a trip to Arkansas this past weekend and went to Searcy to grab some parts from Sam and Alfredo up there, they let me drive their ‘78 FJ55, so I obviously left with an intense desire to get mine on the road.
I left with 3 60 series rear axles, a spare H42 and some extra 80 and 60 parts. At least two of the axles have 3:70s in them so I’ll be able to go ahead and start building my axles for the Pig soon.
After departing Searcy I stopped by the Neon Pig in Tupelo and grabbed a burger, and saw a reminder of SSS2019 on their grill, I believe placed by @cruiserjunktion
Time to order some more parts!
