- Thread starter
- #1,701
In parallel to building the flares, I had ordered a U-Bolt flip from 4Plus, and a Heavy/Heavy OME lift kit from Curt at Cruiser outfitters. So while I was waiting for paint to dry and welds to cool, I was working on getting this set up. As always, there were hurdles...
The kit I ordered from Kurt was essentially a set of shackles, shocks, and springs. The rest I'd re-use my existing suspension components (or replace with 4Plus stuff).
Things started out simply enough - jack up the truck, drop the old springs, U-Bolts, and retainer plates:
The next step was to mock-up the U-Bolt flip kit. The 4Plus kit comes provisioned to allow you to bore a new hole in your spring perch, and shift the axle back about an inch. Given that I still have tiny 31" tires and a HUGE cut-out in the rear with the new flares, I figured centering the tires in the well would be a good way to go.
Mock-up of the kit for drilling the perch revealed a litany of new problems. The brake tabs I'd welded on during the disk brake conversion were just a tiny bit too short, so now the soft lines to the caliper would be rubbing on the U-Bolt plate once fully installed.
Likewise, this loop in the brake line would no longer fit, so I'd need to re-route the rear hard lines as well.
