I finally got my J springs on...
I ordered the kit from Man-A-Fre and was really impressed with them. There was a mild problem in the begining but the customer service team went over and about their call of duty to make it right. Thanks guys!
The springs and shocks were quite simple: I just jacked the truck up from the axle, put jackstands on the frame as close as I could get to the arms, took the tires off, removed the shocks, then lowered the axle down far enough to wiggle the springs free. (Just make sure not to over-strech the break lines!)
The steering dampener was a little more difficult because the factory dampener is pressed on. You also need to press on the new OME studs. Not bad, just not as easy!
I also replaced the brake lines: simple and straight forward. BTW- the pedel feel with the stainless steel lines are amazing.
I still haven't done any castor correction yet, I want to find out how off I am before I press in the OME bushings. That will be done tomorrow.
All and all, I love it. I was able to remove my rear swaybar and my handling is about the same. The scary super-soft suspension is now comfy and firm. This is great quality stuff...
Line-X on the horizon?
