4Cruisers
Now that my '86 FJ60 build is pretty much done, it's time to start on my '71 FJ40. Last week I brought it back to New Mexico after 17 years, it's been waiting its turn out in Nevada since 2001.
Here are some vital statistics to get started:
Purchased: June 5, 1997
Build Date: December 1970
Engine: 2F (from FJ40/FJ55), 2F 067849 (build date between November 1975 and February 1976); OEM carburetor and non-US vacuum advance points distributor with octane selector
Bellhousing: 4-speed bellhousing
Driveshafts: FJ40 4-speed front and rear driveshafts
Transmission: H42 4-speed (from ’78 FJ55) - Sold recently
Transfer case: 4-speed transfer case (from ’78 FJ55) - Sold recently
Suspension: Stock
Wheels: 15” Toyota wheels (from FJ60/FJ62)
Tires: B.F. Goodrich 30X9.50R15 All Terrain
Rear axle: Original with coarse spline 4:11 differential and drum brakes; 4-speed pinion flanges to match driveshaft bolt pattern
Front axle: Modified with Toyota mini-truck Birfields, knuckles, and locking hubs; FJ60 vented rotors; and '91 4-Runner IFS calipers; 4-speed pinion flanges to match driveshaft bolt pattern
Steering: ’83 Toyota mini-truck power steering gearbox, '84 4WD Toyota Tercel pump, and '84 Toyota Cressida pump adjusting bracket; steering column (from '75 FJ40)
Rollbar: Aftermarket rollbar
My preliminary plans for further upgrades:
Engine: 2F with ~66,000 original miles (from my '76 FJ40), already upgraded with FJ60 electronic ignition and oil cooler; OEM carburetor with vacuum advance port
Transmission: H41 4-speed with ~45,000 miles (from '84 HJ47)
Transfer case: Drum parking brake split transfer case (from '85 BJ45)
Suspension: OME with 2" lift
Wheels: 70-Series Land Cruiser 16" wheels
Tires: B.F. Goodrich LT235/85R16 All Terrain
Body: Early front bib with running lights; '77 FJ40 kick-out vent window hardtop sides; extensive rust repair; refurbished hardtop; new Pollux Orange paint job
Seats: Refurbished FJ40 bucket seats with SOR foam (from my '76 FJ40); refurbished short rear jump seats (from my '76 FJ40)
Safety: 3-point shoulder harness seat belts; later OEM rollbar to allow for access to kick-out vent window latches
Winch: Warn 8274 (from my '76 FJ40)
Here's an old photo of the '71 FJ40 (on the right) and the '76 FJ40 side-by-side after one of the infrequent Las Vegas snowfalls:
I also considered installing a 2FE or 3FE but decided to transplant the low-mileage 2F from my '76 FJ40. For the type of driving I'll be doing in the '71 the electronic ignition 2F/H41/split transfer case combination will be more than adequate.
More to come.
Suspension: Stock
More to come.
