fyton2v
Now that the electrical system bugs are sorted out... I need to tackle the mechanical stuff.
The truck sat for pretty long time without running. Maybe 8 years. When it went into hibernation it didn't have this problem, since then it was mostly disassembled and reassembled and kept inside a garage for the whole time.
The first order of business is that the truck tries to stall when you floor it from an idle. It's idling nicely at about 650 rpm. Timing seems good at 7 degrees before TDC. Vacuum is pulling just above 15 PSI at idle and steady. I can see that the that the accelerator pump is supplying a squirt of fuel when i'm pulling up on the throttle with the engine off. Plenty of fuel in the bowl. I can't find any vacuum leaks, but that doesn't mean there aren't any. 15 PSI seems to be on the low side from what I've been reading, however I'm quickly running out of knowledge here.
What would you check first?
George
George
