I have been reading some of the posts that discuss the benefits of one fan type over the other, but have not found a reference to testing the function of the fan clutch.
My assumption is that I should drive for some time and let heat build up, then pull over and with the engine stopped spin the fan - if there is resistance (how much?),
then my clutch is working? IF not, then my clutch is shot?
It has been in the mid 90's to 100's for the past few days here in Vegas - should my clutch engage at a particular temperature?
My engine temp was up around 190deg F while moving it on the freeway - doing about 75-80
(?) (Hard to tell exact speed with the bigger tires and floating speedo.) I haven't tested the fan HOT as of yet, but when its cold it spins freely.
I have my fingers crossed that my fan is working - though after pushing the beast up some good hills I do see the temp go up (didn't have a real gauge at the time) but it gets into the 2/3 region of the stock gauge. This is running about 12PSI of boost. (gauges are nice to finally have).
BTW: My radiator seems fine - though a new cap wouldn't hurt.
