At idle(traffic jam), after an extended duration, on a hot day, with the a/c thermostat on full and the blower on max how hight should the temperature on a PZJ 70 be?
Where are you located and what was the ambient temp. while you were setting in traffic? ..............1978HJ45
My temps. based on A/C (on) with ambient temps. in the 34 + degree (C) range will average approximately 190 to 200 degrees (F) at idle and increase to 210 to 215 at road speed.
With A/C (off) the temps seldom go above 195 degrees (F).
Hope that helps .....1978HJ75
Fan Chung-yen said, not to material happiness, not to have been sad. ed hardy shirtsChinese society from the Song to 2000, is now fast, I dare not say that all Chinese are not as ancient, but at least we have to learn self-cultivation of Fan Tao,ed hardy shoes Dan Kan win or lose, live happily, or someday you for China which teams they lost to weak teams in Asia and a terminal of a branch, ed hardywho will send you a medal then?
WTF - I thought we were all reasonably smart on this forum I think one has slipped through the net.
If its overheats, then it could be down to overfilling the AC, but also check the adjuster puller for the belt.At idle(traffic jam), after an extended duration, on a hot day, with the a/c thermostat on full and the blower on max how hight should the temperature on a PZJ 70 be?
