Just picked up my '05 470 and the first thing I did was to measure fender lip to hub centers and then raise the front end where it should belong. At 190K miles, I expected some settling. I am in my 70's and find the same thing is happening to me.
I used YotaMD's cheat sheet and my old Panasonic Tough Book with TechStreem. That TB is a slow heavy brick.
I found a few things interesting.
First- if I disconnect the AHC temperature connector I get no data for the accumulator pressure----and the rear pressure is way low. I repeated this about five times today and still the same. Went under and checked the accumulator connector and all is well. I also had data yesterday with the sensor connected so I figured this was the issue.
So I reconnected the temperature sensor and the accumulator came online and the rear pressure went from 2.9 to 6.9.
I am low on the Left Rear (20") so I am thinking this is the cause for the 6.9 pressure--- so time for new rear springs. If I want stock is the OEMs the only way to go?
Has anyone else had no data for the accumulator pressure and wonky rear pressure with the temp sensor disconnected?
