Temp, PSI question on a 3B
David*BJ70
Looking forward to reach the end of the world
Montréal, Canada
I just finish the instalation of a water and oil pressur mech. gage on my 3B.
What is the running normal Temp :
What is the normal PSI : 6-8 at idle... but at 3000pm ? FMS show 36-85psi. Is it what you get ?
Thank ;)
Lacus Oblivionis
well, on the 3b in my 40, when I start it cold the oil pressure shoots up to 70ish, then backs down to 25 or so when warm, and when it's really warm it generally idles at around 20 or so.
driving its usually in the 40's and 50's.
the one in my 70 seems to be about the same, tho I can't comment on driving yet...( sooooon )
cheers,
ryan
fjbj40
east coast Canada
you should be a 190 - 195 on your temp gauge after it stabilizes and oil press at 2400 rpm , when it is all warmed up to normal temp , could vary depending on you engine condition . My 3b is at 50-55 psi at 2500 rpm , at idle it is 15 psi @ 800rpm.
Oil pressure will vary with outside temp...in summer it will be lower in winter it will be higher .
Daryl
Tapage
Club 4X4 Panamá
Panamá
The factory Toyota manaul for my 2H engine ( very similar engines ) claims for 62 PSI at 2000 rpm with normal operative temp.
Victoria, Australia
Just a side issue along the same lines, if 190-195 is considered normal temp what would be a tempreture where should think oh $hit it's time to pull over
BJ
Tapage
Club 4X4 Panamá
Panamá
I would recomend check the real temp by one Pyrometer .. I thought when yor factory temp gauge go in to red zone, maybe you have more than 1250 ºF in your EGT ..
crushers
post ho
Tara Ontario
actually, after extensive testing i have found that the pyro can read 900F and the water temp go into the red and i have seen the pyro running at 1400F and the water temp not move...
cheers
Tapage
Club 4X4 Panamá
Panamá
cheers
It means no direct relation with EGT and water temp .. ?
crushers
post ho
Tara Ontario
not that i have found, i was confused at first but over the years this is what i have experienced.
cheers
tlcruiserman
San Diego, CA USA
Daryl
The temp will be as stated if you have the higher thermostat installed (or normal for most places that is 88C) if you have the 82c installed you can nock 5 or 10 off the temp putting it at 180f - 185f.
Cheers,
Michael
tlcruiserman
San Diego, CA USA
cheers
I agree with wayne, I have done extensive testing on this as well and there is really no corrolation between the EGT and the Water Temp. You can reley on both being up there if you push the engine way to hard that is the only time I have seen them corrolate.
Michael
