Well, I think I screwed up (slightly?) right off the bat this afternoon. The first thing I did was to install the new Marlin Crawler inner axle seals in the axle housing. Then I came in the house to read in the FSM the procedure for centering the knuckle and determining the total shim thickness for proper bearing preload. Well, the first step in that procedure is to remove the inner axle seals - duh! The knuckle centering tool has to be inserted into the housing and that can't be done with the seal in there.
I read through all of the extensive service documentation and receipts from the previous (original) owner, and it turns out the inner axle seals were replaced at one time, at Sauter Toyota in Santa Fe. I'm assuming the seals were replaced after pulling the axle shafts, without the steering arm, lower bearing cap, or knuckle needing to be removed. There is no evidence that the front axle was ever rebuilt beyond this. If that's the case, the upper and lower shims I removed (and kept track of their location
) should be how they came from the factory. I'm thinking I'm OK to reassemble the axle using the existing shims in their original locations. I should be able to confirm I'm OK when I measure the knuckle bearing preload. And by using Marlin's upgraded seals, I should be good w.r.t. keeping the gear oil from mixing with the knuckle grease over time.
Am I being overly concerned about this, or should I forge ahead?
