Techstream owners manual
I am not sure what you mean by ride height adjusters. Its not just 2 similar vehicle there is heaps more around. Calibration is what we have been looking at but need to confirm what needs calibrating if it is possible of course
So I'm not sure if your vehicle model has this, but there is a "height control sensor" which is mounted on the Front left upper control arm(there is another in the rear). You can adjust that sensor height, but I'm not sure if this is on all models or only the suspension with the accumulators and such. Anyways, in the calibration procedures, there is a "vehicle height offset calibration" specific to "active height control", and also a "zero point calibration of G sensor" in the VSC.
I attached the procedures to reset all those systems when anything "VSC" related has been modified. It can't hurt to re calibrate!
  • g.pdf
    g.pdf
Thanks but I have done that must be 20 times during all the attempted fixes
This is exactly what i was hoping to get out of this thread. I have the FSM and techstream; however, there's not a lot of information on how to use a lot of the techstream utilities. The FSM calls for the Height offset calibration, but there's no procedure on how to properly use it. I've learned a lot through trial and error, but it's a lot of work to get the rig leveled on my driveway in order to start playing.
Hope it works for you
