Alright guys...here's an attempt to describe the Tech Day planned for Saturday the 28thth of April.
Job:
Replace rear differential
Replace rear axle bearings and seals
Replace front output bearing
Parts for Replacing Rear Diff:
-Donor 3rd Member (Thanks Tom!)
-Front (paper) and Rear (cork) differential Gaskets
-One good stake nut that has not been staked previously
-3 quarts of gear oil
Parts for Replacing Rear Axle Bearings and Seals:
--Two Koyo rear wheel bearings and races
-Two Rear wheel bearing seals
-two tubs of drum brake bearing grease
Parts for replacing the Front Output Bearing
-Gasket for cone
-Bearing
Tools I have for the Job:
1. Metric wrench set..
2. Metric socket set..
3. Hammers...but no BFH
4. Dremel with cutoff attachments
5. Electric drill...no good bits to speak of...
6. Other misc. tools (screwdrivers, wrenches, etc)
7. Razor blade to remove the old gasket material. I think that the PO used Blue goop instead of the paper gasket.
Tools we NEED for the job:
1. Welder (to get the rear wheel bearings out)
2. Bearing puller (John Smith ordered but yet to receive)
3. longer handled socket wrench, mine is pretty short.
4. ???
I figure we could start this job at around 9am and try to finish before 3pm. Just a ballpark guess on my part......
Job:
-Gasket for cone
-Bearing
4. ???
