TC.Idler gear toasted???? Any tips???
Costa Rica
Website
www.orodesigns.com
Hoping some one can give me a tip on how to fix the inner race on an a 1965 3 speed idler gear in this transfer case.
I pulled it apart and was going to replace the bearings etc...
After a closer look I realized the races are roasted. Oval on one side.
I am in Central America and it is no treat getting things done here.
Finding the needle bearings took the better part of the afternoon.
I doubt I will find an other idler gear here for this unit. At least not a 65.
Are they interchangable and if so up to what year????
Thought about the sleeve thing but a machine shop is behind the times and I would be hard pressed to have this done.
Any suggestions much appreciated.
Beef beer and broads in Costa Rica.
Salute
Steve@orodesigns.com
I am virtually certain all 3 speed box gears will interchange. You have, I suspect, two choices: find a box in a junkyard and raid it or buy a gear from a vendor or one of us and wait for shipping.
I may have a spare idler gear to fit your TC; it just arrived today. I'll unpack it and see if I can post a pic for you.
I found a guy today with a T case but he is out of his mind.
67 TC for $500.00
Not even rebuilt
I am wondering if it would be possible to bore out the race and go with a larger bearing.
It seems this is the weak link in these cases.
Any feed back would be great.
Cheers
Steve / hammered
Is it that the bearing race spun in the housing? If so you might get away with a expanding locktite that is slow curing as a temp fix that might last until you get a new unit from the states. If you can put together and torque to specs it should be real close to centered. Just a suggestion, you don't have high speeds there and I don't recall many cars being junked there, at least that I saw,so used parts are probally as scarce as new.
I still have a 3spd idle gear cluster sitting on top of my work bench, I gave it away 5 years ago but the dude never came to collect it and he eventually sold his cruiser. You can have it for the price of shipping to your place and a Costa Rica sticker.
Let me know.
/td
Hey Mustar that is ba real nice offer! Thanks Man. Very generous of you to offer up.
I may have solved the problem.
Went to a bearing shop here and found a needle bearing with a 1" ID and an out casing.
I am having a shop Machine out the race and set these new bearings.
If it works I will let you guys know.
It maybe a cheap fix for this weak link in the transfer chain.
I think it will be even a stronger unit when done. That is if he can ream out the meat in the bearing race. Hard stuff.
I will know today if he was successful.
Thanks for the input and offers.
Felize navidad
Steve will be hammered on during holidays. hahahhahah....
been hammering on the cruiser for a week now with no problems.
just got back from a 600 mile tour and it still is great. NO SOUNDS!
Easy fix for future referance REeam out the idler and put in a bigger bearing with and outter jacket.
Cheers and thanks for the input.
Steve
