I purchased the Howell TBI wiring harness for the cruiser and think I have it mostly wired up......except the main ignition. The howell harness only requires one wire to be hooked up (with it's own fuses) to a key start ign source but the power cannot cut out when starting.
After researching, I'm guessing this keyed source would be the black with yellow stripe wire that also goes to the coil?
The other question is that my alternator needs an ignition source to "excite" the alternator besides the constant hot direct to battery for charging. Any idea on the color wire of the stock 40 harness to connect that to?
