TBI 4.3/5SPD in an FJ?
Discussion in '40- & 55-Series Tech' started by TRAILTOYZ, Aug 28, 2006.
  1. TRAILTOYZ
    TRAILTOYZ
    180
    Jul 13, 2004
    Wasilla, AK
    Anybody done this one. I picked up a 91 4x4 S-10 with a low-mi TBI 4.3 motor & 5spd tranny. Will this bolt right up using the regular 350 motor mounts? I think it's mated to an NP208. How would you recommend going about this? It'd be cool to go to a 5 speed from the 4spd thats in there.
    Erik
  2. spctrbytz
    spctrbytz
    99
    Aug 13, 2006
    Abilene, Texas
    4.3 uses SBC mounts as far as I know, and a nice motor all the way around.
  3. bandy rooster
    bandy rooster
    1,935
    3
    Aug 11, 2005
    Sunny South
    people have done the 4.3 swap.. still gives decent power but better fuel milage and the def. added bonus of having TBI. if i were to do the 350 swap again i'd give the 4.3 a try. from what i've heard the 350 block and the 4.3 is the same block with just 2 cyl. less. I beleive the stock motor mounts will bolt up to it. What 5 speed trannsmission is in it? i'd get rid of the NP208 though...
  4. TRAILTOYZ
    TRAILTOYZ
    180
    Jul 13, 2004
    Wasilla, AK
    It should put out plenty of power to push the pig. It's about 30 more HP and weighs alot less.
  5. dustin
    dustin
    701
    1
    Oct 19, 2004
    its same as a TBI 350 conversion, with exception of the flywheel, the motormounts are in a different location, and you may have trouble with the manifolds unless you get creative (like swapping them left to right) running center dump headers, or van manifolds. I had a 94tbi in my 40 before I swapped in the v8. its decent, economical, and can get some power out, though TBI isnt a hp monster.. You will be good with the stock radiator- plenty of cooling.
    -Dustin
  6. jaacina
    jaacina
    48
    Sep 12, 2005
    St Paul, MN
    S10 5speed will not work.
  7. projektdotnet
    projektdotnet
    1,839
    Sep 26, 2005
    Port Orchard, WA
    Why not...if he uses the chev t-case and centered rear axle?
  8. bandy rooster
    bandy rooster
    1,935
    3
    Aug 11, 2005
    Sunny South
    i've never heard of a 4WD s-10 but i could be wrong... if so you'd have to use a divorced transfer case and then it just wouldn't be worth the work, and the fj40 doesn't have the wheel base to do a tricky divorced case build... (although i'm sure it could be done ie-300D)
    my bad = i'm retarded...
  9. lone gunman
    lone gunman
    1,399
    14
    Aug 17, 2003
    granite falls WA.
    do a search texican did a beutifull install of a 4.3 into a 40 with lots of pics and how he did it.
  10. ranger
    ranger
    1,164
    6
    Jan 18, 2003
    Mountain Hole, Idaho
    There are plenty of 4WD S-10 pickups and Blazers. They were Chevy/GMCs economical version of 4WDs, Ford had the Bronco IIs.
  11. Mark W
    Mark W
    6,182
    94
    Jan 7, 2005
    The Greatland
    ??? 4wd S10s are a dime a dozen round here. And worth at least half of that cost. ;)
    Mark...
  12. TRAILTOYZ
    TRAILTOYZ
    180
    Jul 13, 2004
    Wasilla, AK
    Texican did a beautiful job in that writeup. Looks like a long winter project though. Any advantage to a vortec over a TBI motor (other than HP)? I've heard the vortecs can give you alot of injector issues if the PSI isn't exact.
    Would the regular 350 conversion bellhousing work on the 4.3, or would it be better to just mate it up to an SM465? Can you run the stock T-case with the 465?
    And yes, 4wd S-10's are plentiful up here :)
