Hey all-
Has anyone tapped one of the unused fuse locations connected to the IG1 relay bus in the engine compartment fusebox (2016 MY)? Ideally, I’d like to add a new wire with a female connector that can snap into the underside of the fusebox panel. I think this would provide a near-factory install complete with a dedicated fuse.
However, I can’t see an obvious way to lift off the fuse/relay plastic mounting grid to access the underside. I assume there are a few hidden/plastic clips that hold in the panels (Looks like the IGN1 relay is a part of a fuse module called “Unit A”?) I also worry that the wiring on the underside is so tight that it makes it difficult or risky to access. Has anyone done this before and any advice?
Here's a picture of the IG1 relay and the 5 open connections that would be ideal to add a circuit/fuse to.
As an alternative, I searched and found that a lot of other folks have simply tapped the +12 ign from the top of the fuse panel with an add-a-fuse so if it’s not feasible to access the bottom maybe that is my plan B. That would be super easy for sure but curious about hitting it from the underside.
Or, as a plan c, I might resort to running a new line from a generally unused circuit (like from the cig lighter) to the engine compartment to provide the +12v ignition signal. I thought about tapping into another IG1 circuit at the load where the wires are exposed (like washer, seat heaters) but I think prefer to keep the circuits independent.
But with all the IG1 open connections just sitting there I figured I’d ask in case I’m missing something obvious. Has anyone done this or have a different recommendation (plan d
(I’m planning to connect this +12v ign signal to a relay to switch power for a new ignition bus in the engine compartment so load on the source circuit would be minimal.)
Thanks!
Jeff
Thanks!
Jeff
