Tapping Noise In Front Of Oil Pan No. 2 (Timing Chain? Oil Pump?)
Seacoast NH
Hello All,
I have a curious noise that I can hear at idle. It is a hollow tapping sound that resonates from the area outlined in red below.
If you put your hand in that area while the truck is running, you can feel the tapping; is this normal?
For lack of an audio clip, at idle, the noise kind of reminds me of the sound a pot of thick stew makes if it is let to boil; just at a faster cadence.
What do you think the noise is?
Thanks a bunch everyone.
- Josh
After looking at the FSM, I figured out why no one wanted to answer my questions.
Edited.
I'd bet your truck is sitting at a slight incline with the front of the truck lower than the back.
Sounds kinda of scary but several on the forum (including myself) have decided it's nothing more than the crankshaft slamming into the oil in the pan.
I do not hear it when on level or when the front is higher than the rear.
If you're hearing it at all angles then it sounds expensive.
THANKS!
You are 100% correct! I do only hear it when the truck is nosed down, but didn't realize it.
That eases my mind. Thanks a lot, lowbanks!
