I want to add a natural gas quick connect to the outside of my house like used for grills. I am planning on purchasing a tri fuel generator and want to use this for the primary fuel source. I see 2 different options for tapping an existing line.
1. Easiest but most risky. Put a 90 degree elbow on the capped T on the left side of the picture. I can turn off the gas at the meter but the system in the house will still be pressurized. If I can put a capped elbow on quickly there will be a minimal loss of gas. If not I am not sure how much gas will leak leak out.
2. Turn the gas off at the valve on the right. This line runs to the fireplace. Disconnect the pipe on the right side of the valve and add a T connection with another valve. This section of pipe is about 20' long and will probably need to be shortened about 2 inches.
Any other suggestions or words of wisdom? Thanks in advance for any advice.
