Tansfercase swap
Fallon,NV
Ok gang this is the deal i have an 89 toyota pickup as you all know t\i think the t-case is going south what i need to know is what do i need to swap a 4 speed t-case with the auto t-case ?
Dan :cheers::steer::bounce::bounce2:
Dan, I'm not sure what it is you are asking.
Is your mini an auto? Are you asking if you can put the 4spd t-case from your 40 into your mini?
If so, then you can't. At least not without a whole lot of money and then your rear output would be offset. So while you have it, that doesn't make it a good deal.;)
You should be able to pick up a junkyard t-case pretty cheap for your truck, they aren't t-cases that people want, so I would think that the JY's would be pretty reasonable on one.
Have you looked into rebuilding yours and what makes you think your t-case is going bad?
Jack
No i actually have a 4 speed t-case from a mini that i want to replace my auto t-case with in my mini as my t-case in my mini is having issues
Sorry, I'm with you now.
Marlin "might" have an adapter, but I'm not sure. You could call him, but off hand, I know it won't just bolt up.
Jack
