I was just reading about one of the guys with a gasser mounting a tailpipe turbo,
https://forum.ih8mud.com/80-series-tech/97252-junk-yard-turbo.html
(A ways down the page)which sounds like it has its share of advantages and disadvantages. Is that something that could work with a diesel? All the vehicles they referred to having such a setup were petrol beasts. The air cleaner on my Hiace van is way down low, right near to where The 18" front-pipe slants down from the engine compartment. So it might work out to put a turbo around there, where the exhaust is still moving with a lot of force, and right by the path the air usually takes in anyway.
The usual problem with throwing a turbo on a 3-L Hiace is that doing so increases the heat in the nicely insulted engine compartment, making head failure more likely.
However, if the turbo were elsewhere, it would not heat up the engine compartment, and if it were outside the compartment, it would run cooler. Is this an insane idea for a diesel?
