t-case squeal?
Discussion in '60-Series Wagons' started by peepers, Jun 27, 2005.
  1. peepers
    peepers
    2,082
    2
    Jun 30, 2003
    After some light wheeling I noticed a odd squeeling from under the truck when I would lift from the accelerator going around 20 - 30 mph. At first I thought something was loose and rattling but I could not find anything. When I looked under it again, I noticed a small wet spot on the street. Right above it was where the rear drive shaft meets the transfer case.
    [​IMG]
    You can see a small drip in the pic. The full res can be found here:
    http://fj62.net/images/drip.JPG
    While driving today I did not hear the squeal except for when I drove the truck in reverse.
    Any ideas?
  2. wingysataday
    wingysataday
    789
    Media:
    1
    184
    May 16, 2005
    Boise
    Get The Oil Changed In Your Tranny And X-fer Case And See If That Changes Anything
  3. lowtideride
    lowtideride
    7,611
    Media:
    12
    Albums:
    1
    83
    Sep 29, 2003
    The Sunshine State
    squeal might not be coming from the t-case...
    and my case always looks like that after wheeling....most 60s cases do. its when they stop leaking you should worry.
    i would check the brakes for the squeal.
  4. Cruiserdrew
    Cruiserdrew On the way there SILVER Star
    15,587
    4,637
    Mar 15, 2003
    Sacramento, CA
    It might be the transfer case rear output bearing going bad. Was the transfer case ever low on gear oil? As the bearing goes bad, there is more slop in the output shaft and the output shaft seal will leak. The bad news is that you will pretty much need to rebuild the t-case to fix. I just did one, and if I can rebuild a split case, you can too. Fix it soon or it could trash the output shaft which could add considerably to the cost of a rebuild.
    You might measure the preload in the output shaft-shift the t-case into neutral, pull the output flange and measure the turning force. If you feel any play or there is no preload, then a full case rebuild is in order. Good luck.
  5. peepers
    peepers
    2,082
    2
    Jun 30, 2003
    i am going to replace the seal in there and fill her up... see if the noise is still there. i hope the bearing is fine. i barely drive it after hearing the noise originally...
