t/case paint?
wombat
Victoria B.C.
i am going to install a 3-sd t/case in my 76 fj40 and i have got it all cleaned up. now the question is should i leave it as is or paint it,if i paint it what kind and colour of paint?
pbgbottle
Forum Lifer
Cloverdale B.C. Canada
i painted mine .:doh: just because i wanted it to look new i was spray painitng the tranny (rattle can rust paint ) and just never stopped painted everything . :grinpimp: didn't really care if it pealed off its a cruiser. to this day the paint still hasn't come off.:grinpimp:
inkpot
All over Arizona
No need to paint it. Aluminum doesn't rust.
Howdy! Long time ago someone suggested using clear coat/urethane. Doesn't look any different, but it fills in the rough casting texture so it is much easier to clean off trail dirt/grease whatever. I did mine that way, and a quick shot with the garden hose cleans it right up. John
CruisinGA
Georgia Tech
I like clear coat or silver "aluminum" paint that looks "normal" but cleans up much easier than bare aluminum.
I sandblasted my case and did not paint it, I wish I had
KLF
Frame waxer
Southern NH
True that it doesn't "rust" in the typical form that iron-based materials will, but it will corrode like crazy. The R151F tranny I got out of a turbo pickup looked like CRAP after 180K miles in Massachusetts, but after bead-blasting and 3 coats of Rustoleum, it looks like this now:
The t-case will get the same treatment after I get the crawler gears installed.
wombat
Victoria B.C.
Thanks guys,so the official count is.
3-for leave it buck naked
7-paint it
1-powder coat (sunglasses required while viewing)
Living on the wet coast everything rusts corrodes or molds its going to get a rattle can of newfie chrome.In the 24 hours since i cleaned it it is already started to corrode.
New Hampshire
I painted mine silver a few years ago when I rebuilt it. The oil that began leaking again from the parking brake drum 3 months later now wipes right off! I need to do the double seal trick.
e rock
Monroe, WA
Aluminum, even morso than iron, has an infinity for oxygen.
Or affinity, whatever :D
But the difference is that aluminum oxide forms a barrier on the surface, preventing the underlying material from corroding. Iron oxide does not.
East Hanover, NJ
Actually you can put a controlled layer of aluminum oxide on it and actually die the aluminum oxide different colors while it is still soft.
That's way too much work and costs way more than a few good coats with a rattle can.
El Salvador and Washington, D.C.
Get ready....
Here it comes...
Powder coat it.... :grinpimp:
True that it doesn't "rust" in the typical form that iron-based materials will, but it will corrode like crazy. The R151F tranny I got out of a turbo pickup looked like **** after 180K miles in Massachusetts, but after bead-blasting and 3 coats of Rustoleum, it looks like this now:
OMG, you guys stuff looks SWEEEET. I can see now that I'm gonna have to step my game. So clean off the metal, rattle can well and the urethane clear to seal the deal. NICE.:clap:
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
It starts off shiney. It's very bling bling. As long as it's kept out of the mud it will tarnish a bit but still look pretty good. For a stocker no pain is what I do.
For something that is going to get muddy and dirty it doesn't really matter. First time you go through mud it's gonna get coated and then baked on from the engine heat going back home. Then are you really gonna take the skid plate off and clean it every time.
My idea. I paint. But I do it with something that is thick. Rust Bullets works well because it's like wrapping everything in a plastic bag. If that gasket or seal was going to leak it won't have a chance getting through that stuff. I like no oil leaks. If it came in brown that's what color I would have painted it.
I feel sorry for the bastard that wants to bring this case back to stock.
