I've had two instances within the last 18 months when my hi-low shift linkage dropped into the t-case rendering the 60 stuck in low. I've had the t-case apart in the past at least twice and it's not been clear to me how to reinstall the hi-lo shift lever, and I've noticed any difference in how to install it until today.
The outer and inner shift levers.
First time the inner hi-lo shift lever dropped into the t-case we pulled the rear half, reinstalled the shift lever and added an extra washer on the outside of the t-case to hold the shift lever higher. In this instance the long arm of the outer shift lever was oriented up. Like this.
Yesterday I had shifted into low range and the inner dropped into the t-case. Today I pulled off the back half to fix the issue. What was puzzling is the the cross bolt was tight so how did the inner arm drop into the t-case. These parts are substantial and see essentially no wear, therefore it's not a wear issue. With the levers in hand and cleaned I tested each orientation. With the outer lever attached to the inner shift lever and with the long arm on top there is a looseness even with the cross bolt fully tightened.
Flipping the outer shift lever so that the long arm is down and with the cross bolt fully tightened there is no looseness.
If the proper orientation of the our shift lever is noted in the FSM or elsewhere I've overlooked it and in photos of new assembled t-cases don't think I've noticed a consistency.
