t/c trans. assembly
Discussion in '40- & 55-Series Tech' started by madoc1, Jul 29, 2005.
  1. madoc1
    madoc1
    436
    8
    May 28, 2005
    spicewood,tx.
    mated the orion to stock 4 speed today. what a chore. super humid and hot shop. any way, the question is why do they make the rear trans bearing in the t/c fit so tightly on the trns output shaft?
    it seems to me that the tightening of the nut on the end would sqweeze all of the parts together so that the inner race does not spin on the shaft.
    had to make and use a number of spacers, each larger to pull the assembly together. used cut up sched 40 fittings, much easier to cut.
    maybe just me or the humidity, but if i ever have do this again, does anyone have a better solution? thinking a diifferent bearing, maybe .001 larger i.d.?
    thx for any ideas. i dont think i screwed up but i never know.
    jim
  2. peesalot
    peesalot
    2,398
    91
    Sep 20, 2004
    here
    you mean the very last bearing under the cone ?
    Mine slid on fine , never heard of one going on like a press fit .
    Make sure the washer on the end under cone is not pinching the inner race of bearing , this will put thrust load on it and that is bad. The inner race should be just past the shoulder in shaft so this won't happen but it does , often ......
  3. madoc1
    madoc1
    436
    8
    May 28, 2005
    spicewood,tx.
    pees, didnt look at that but will. i dont under stand either. put on the new gear before ever trying to assemble any thing and slipped right on. used two bolts to align everything,. since this comes with a new long bolt i just ground off the head of one the old ones. for the other one found that a sae course bolt is a nice fit in trans. not tight and not loose and pulls right out when you are done with no damage to the trans threads
    its together now but if pops out of gear i sure would like an easier rebuild. maybe a buddy would help.
    jim :) :beer:
  4. madoc1
    madoc1
    436
    8
    May 28, 2005
    spicewood,tx.
    pees, just reread what you said. my orion set up is (at least this how i did it) istrans- spacer-new gear-rough finish long pto sub spacer- tight ass bearing- shorter ! 1/4? spacer- thick washer -nut.inner race is way beyond end of threads. it all seems to fit. did i fck up?
    jim
  5. peesalot
    peesalot
    2,398
    91
    Sep 20, 2004
    here
    given the stack order then the edge of the 1/4 spacer should be just past the shoulder in the outputshaft so the thick washer does not squeeze it .
    1/4 spacer behind bearing does not ring true to me . PM poser and treeroot or check the pics in treeroots thread , it gives you a very defenite clear pic of the exact situation you are discussing.
  6. madoc1
    madoc1
    436
    8
    May 28, 2005
    spicewood,tx.
    if i remember correctly, tree uses a different trans. dont know if this amounts to hill of beans difference but go back and double check all i can find. thx jim
  7. madoc1
    madoc1
    436
    8
    May 28, 2005
    spicewood,tx.
    ok poser where art thou? do yYOU have problems mating the t/c with the trans or am i the only old weak fart out here that does? jim
  8. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    27
    Jan 22, 2003
    Kansastitty
    I think Poser is out in the Black Hills.
    Ed
  9. treerootCO
    treerootCO Where are my keys?! SILVER Star
    3,781
    Media:
    45
    Albums:
    1
    826
    Jun 2, 2004
    Wheat Ridge CO
    Poser is wheeling. Stock trans to Orion shouldn't have any problems. My issues were trying to breed my Orion with an SM465.
  10. madoc1
    madoc1
    436
    8
    May 28, 2005
    spicewood,tx.
    thnx. we got together this morning, and seems to work fine. my only cocern was pulling the two together. seemed awfully tough. just getting weaker than i thught i was . any way, good run today- did not jump out of gear and no visible leaks. but as i said only first run.
    jim
