Swapping Huge shackle reversal to low pro!
Ocoee Fl
I have a large Man a fre shackle reversal on my 85 Fj60 now. I’m working on my spring over and I want to remove the lager shackle reversal and replace it with a low profile one like the ruff stuff spring hanger. To reduce the amount of objects that catch it. Is it as simple as just replacing the hangers or will I need to reduce the shackle size as well. The rear shackle matches the front in size atm. I’m running stock springs in the rear recently SOA and i have a set of stock springs for the front so my question is. Can I just reduce the hange for a smaller low profile one and still have a level truck? Using stock spring front and rear with the same size shackles?
tmxmotorsports
OBX Nc
Are those jack stands the ones with the recall from harbor freight? I have the same shackle reversal on my 62.
Birmingham, AL
Are you wanting to keep the shackle reversal or flip it back to how it is stock (with shackle in front)?
If I were you, I would cut off the Manafre hangers in the front and put on some ruff stuff spring hangers like these:
and then French the shackle through the frame in the rear like this:
cruisermatt
Un-manufacturable
Supporting Vendor
Winter Park, Florida
Website
www.facebook.com
I don’t think his 60 won’t sit level if he does that. He’s local I’ve already been over there and looked at it
Ocoee Fl
Sorry I did not see any notification to anyone responding. I want to keep the SR just not Man a Fre like matt said he has looked at it and has the ruff stuff spring hangers like mentioned above. And he has also frenched his shackles. I do not want to french my shackles thru my frame at all, I don't want to lower the truck I just want to reduce the size of the front hanger so it does not catch everything. What would be my shackle options if I cut the Man a Fre off put the ruff stuff on and ran what shackle? My rear is a stock spring with a 5' or 6" inversion shackle SOA on 39s. I currently have a Frankenstein spring upfront in the process of SOA. It consists of an OME heavy spring, 1" arch 1" AAL I could take leafs out or I have a stock fj60 spring I could use.
