swapping fj40 diff and/ or locker into 60
West texas
I just spent an hour trying to search this, i understand that there are differences in both diffs and big differences between the entire axles.
I have a buddy who has spare diffs that are 4.10 and they are both locked out of a fj40. Is the swap possible?
Thanks for the info
Whidbey Island, WA
The pinion flanges might be different, but other than that the third member should be the same from 1975-1990. Housings are not interchangeable, knuckles and birfs are the same after 78 if I remember right and I think the right side inner axle could be the same not sure.
Tony
Granite Grinder
IH8RUST
Moderator
Falkland, BC, Canada
Some early model pinions were course spline, this make swapping pinion flanges problematic. If the the donor 4.11 is fine spline then you won't have a problem swapping flanges, other than that it's a bolt in.
