swapping an H41 for an H42?
Discussion in '60-Series Wagons' started by lovetoski, Jul 24, 2005.
  1. lovetoski
    lovetoski SILVER Star
    4,618
    288
    Jul 13, 2003
    Hi,
    I'm thinking of swapping an H41 in for an H42 (can't afford the H55). My 60 is an 87, so it has the spacer. I'm not real clear on what the H41's came out of, so I don't know if the spacer will bolt right on or not. If the spacer bolts right on, then I guess it's a straight swap?
    Thanks for any advice.
  2. tornadoalleycruiser
    tornadoalleycruiser SILVER Star
    4,391
    294
    Aug 2, 2004
    KC Mo
    it'll bolt on but then you can't put on a tcase.. If you get a 19 spline h41 with or without the spacer your fine but if you get a short H41 then you'll need different driveshafts.
    Another option if you get a short H41 or a 16 spline h41 you should be able to swap tailshafts then use your spacer..
    hope that helps.. EC
  3. Mike S
    Mike S
    2,537
    18
    Aug 19, 2003
    Doug
    I think it will be difficult to find an H41 in the US. I have no idea of the prices, but it may not be much less than an H55F. The H55 will go in pretty easy with no drive train mods, which you might havce to do with H41?
  4. ClemsonCruiser
    ClemsonCruiser
    8,871
    Media:
    1
    Albums:
    1
    1,813
    Feb 17, 2004
    Clemson, South Carolina
    you can pick up and H41 from Man-a-fre for 650 , so it is a fair amount cheaper than the H55
  5. StanCruiserMan
    StanCruiserMan
    121
    1
    Jul 14, 2005
    I don’t think you will find a long H41. The markets that had it just upgraded to the H55 in 1983 instead of getting a longer 4 spd like the USA. I bet you will have to change the shaft or go short...
  6. DocB
    DocB
    641
    7
    Sep 19, 2004
    Amarillo, Texas
    I have one in an 82 I got from Specter, behind a V8. Love it for the money; I'm on 32s with the orig 3.73s and it's about right for moderate wheeling. Great on the street too.
