swapping a 62 auto into a 60 and vice versa
Discussion in '60-Series Wagons' started by Mace, Jul 1, 2005.
  1. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,404
    1,855
    Feb 17, 2002
    Las Vegas
    I assume that it has been done but I am curious. Isit as easy as it sounds? Swap pedals/MC the trannies, driveshafts, shift linkages and clutch/torque converter parts???
    Is the 62 tranny electronically controled????
    And it is a fairly robust tranny right?
  2. Godwin
    Godwin Resident Herpetologist SILVER Star
    4,264
    2,882
    Dec 4, 2004
    Alabama
    Tranny is not electonically controlled. Would have to move the crossmember rearward.
  3. Mace
    21,404
    1,855
    Feb 17, 2002
    Las Vegas
    That is not a big deal at all to me.
    But would you need to move the xmember rearward if it was in a 86 FJ60???
  4. Godwin
    4,264
    2,882
    Dec 4, 2004
    Alabama
    Yes. The A440F tranny is longer than an H42 + spacer combination. Don't know how much exactly but it's only a few inches.
    Or just buy an FJ62 and swap in a 2F.
  5. Man Jerk
    Man Jerk
    2,107
    6
    Jun 28, 2002
    Colorado Springs, CO
    I've done a 4 speed swap into a 62.
    It should be as easy as it sounds. You will have to relocate the crossmember. I cannot think of much that would give you trouble.
  6. dd113
    dd113
    2,922
    2
    Jun 13, 2003
    You will need to fab up some sort of kick down linkage for the tranny. A cool and cheap mod would be the 3F NON USA head w/intake/ex manifolds and a 3F carb with factory kickdown on the 2F block.
  7. Mace
    21,404
    1,855
    Feb 17, 2002
    Las Vegas
    Cooler mod would be a megasquirt TBI mounted on a turbo ;)
    thanks for the info tho.. I never think about kickdown cables..
