- Joined
- Dec 10, 2003
- Threads
- 36
- Messages
- 497
I'm currently in the process of a build-up for my 40 converted to 42 series. Here's the skinny so far:
1) a)Aftermarket tank from Man-a-fre (21 US gal.), mounted above rear axle. Coated with POR to cut down polymerization.
1) b) 250w heat pad on bottom of tank.
1) c) aux. fuel pump to assist transfer pump (with a copper coil T'ed into the coolant feed and returns to the HFPU.
1) d) thermometer in tank. Simple cook thermometer from crappy tire with a compression fitting into the drain plug on the aux. tank.
2) Heated fuel pick-up (HFPU)
3) fuel lines and coolant feed and return to aux. tank all in the same insulated jacket.
4) Flat plate heat exchanger. Coolant heated.
5) raycor filter with a 50w heated sleeve.
6) 6-way GC valve
7) electric trace heater for hard injector lines.
So now I'm trying to decide the same things as many others about purge plumbing. It brings to mind a couple questions:
1)The raycor filter is pretty big. Does anyone know the capacity? It's got to hold more fuel than the stocker.
2)Most set ups have the purge return lines going to the filter input. I'm assuming this is avoid having a filter filled with 'cold honey' on next start-up. Since my filter has a heat sleeve maybe I could T into the filter putput , esssentially right before the valve?
3) my rig is 12 volts. How much amperage does the stocker 12v alternator put out? I'm guessing I'm getting close to my capacity by the time I turn on a fan, lights, wipers, 250w heat pad, 50w heat sleeve, aux. fuel pump, and heat tracer. (some lowlife ripped off my amplified stereo so there's no draw there!)
The GC people have an automated system for purging that's based on 30secs (i think). However, that's based on cars with little filters and lines. I'm wondering what time it might take to purge my rig.
I've seen some posts here that are suggesting 4-5 mins but gosh that seems long compared to the GC people.
Any ideas?
best
Aaron
6) 6-way GC valve
Any ideas?
best
Aaron
