Suspension question
First question, wheelin intent? (rocks, mud, daily driver, trailer queen, etc...)
Now that I think about it, unless it's truely a daily only driver, my choice wouldn't matter.
4-link rear with coilovers.
3-link front with panhard and coilovers IF you plan on retaining a drag link, true 4-link if you plan on full hydraulic steering...coilovers either way.
Custom Alcan springs, stay spring under, use OME shocks. For your uses maybe 1 inch of lift which should work with 31 inch tires.
Spring under = Little Bodyroll and Little Flex or Articulation (Great for the City)
Spring over = Alot of Bodyroll and Alot of Fex ( for the Rocks)
I love my Spring over and the only way i would go spring under is a Stock Restored Cruiser.. (Maybe when im like 60 years old)
I agree with Cruiser drew, if you dont ever take it wheelin get some alcans and stay spring under
Till then i will always be Spring over!!
SUA is stock.
That means you are mostly staying within the parameters Toyota engineered the truck for.
Means less broken parts, more predictable. Not to mention cheaper and easier to install.
I really like my 4" SJ lift for what it is.
For a daily driver I would probably get the 2.5" lift and some 32x9.5 or 33x9.5 tires.
I am really happy with OME stuff, real nice combo for a DD 60 is, OME, 33x10.5's and 4.10 gears.
[quote author=TXcruiser68 link=board=1;threadid=17680;start=msg171149#msg171149 date=1086702864]
mostly daily driver, with a little weekend light wheeling, cruising on some easy trails/ dunes nothing too serious.[/quote]
Are you going to run 33's? With 33's I'd recommend 4" lift rear, SR kit with 2.5" lift springs up front. Or, custom SR with as much lift as required to level out your truck.
With 31's I'd recommend 2.5" rear and SR without lift springs in front.
SR is the single most significant upgrade I know of on Landcruisers. NO MORE WHITE KNUCKLES!
