Do you have a picture? Would love to see how that looks.
Little does anyone know that back in the day, @rkymtnflyfisher had 44's......but there wasn't anywhere to secure the fly-rods and the rumbling 44's scared all the wild trout he was after
For those of you that installed 4" skyjacker lift kits did you install the 4" kit for both front and rear or 2" in front and 4" in rear?
Such a sweet ride!!You should look up his "re-build" thread.....(just kidding)......one of the nicest 40's on the board, but the background scenery really needs some work
8/80Toyota changed from 25mm to 35mm eyes at a certain point, I believe it was 1980.
Someone around here will know the exact date.
Is there a list of components that I SHOULD make sure sure to address with a 4 inch lift?
Shackles
U Joints
Extended Break Lines
Caster Shims?
Thanks, what degree shim should I consider?With a 4" lift you will need caster shims on the front axle for sure, and probably shims on the rear to correct the working angles on the drive shaft u-joints. Extended brake lines a good idea; not sure if they are a requirement or not - I put a 3" lift on mine, with extended shackles, and my stock brake lines are long enough.
Shackle | Shim |
1" - 1 1/2" longer than stock | 2.5 degree |
2" - 2 1/2" longer than stock | 4.0 degree |
3" & longer | 6.0 degree |
SOR has the following in their website, would it depend on the shackle length? What if I kept stock length shackles with the 4 inch lift?
Shackle Shim 1" - 1 1/2" longer than stock 2.5 degree 2" - 2 1/2" longer than stock 4.0 degree 3" & longer 6.0 degree
Bilsteins on my Tundra, 4Runner and FJ40 - nothing but good things from my perspective - caster shims - yes - not sure on degree's, I let Georg at Valley Hybrids tell me what was neededIs there a list of components that I SHOULD make sure sure to address with a 4 inch lift?
Shackles
U Joints
Caster Shims?
I'm considering these shocks: Bilstein 5125 4" Front and Rear
Anyone have any negative reviews for the Bilstein shocks?
Makes sense. This helps a lot.The way to do it right is to measure after the lift. The specs are in the factory service manual for steering caster on the front, and for the back you'll need an angle finder to measure the pinion flange and the transfer case drive flange. A small bit of basic geometry to calculate how much you need to rotate the rear axle to make the u-joint working angles equal but opposite.
The SOR table is rule-of-thumb or a place to start I guess, but there's a lot of variables between different lifts, springs, and shackles.
4-6° shims if 4” lift. At least the stock rear shackles are way too short for 4” lift springs.Thanks, what degree shim should I consider?
That’s right, the spring length is the same.Alright, gave Skyjacker a call.
They said if the post-80 is the same length as the pre-80 FJ's than their kit should fit, the only difference would be the bushings for the thicker leaf pin.
Hence the 25mm vs 35mm options I see in Dobinsons website.
Can someone confirm if this is accurate?
Okay, perfect. I'm getting somewhere!That’s right, the spring length is the same.
What length shackles are needed for the rear for a 4" lift?4-6° shims if 4” lift. At least the stock rear shackles are way too short for 4” lift springs.
