awesomeissquid
Have you thought about adding something like Timbren bump stops to the mix with the OEM shocks? They might assist with the compression over large bumps and stuff.
Good point. Wheeler’s bumps do the same and are quite a bit cheaper than Timbrens.Have you thought about adding something like Timbren bump stops to the mix with the OEM shocks? They might assist with the compression over large bumps and stuff.
It’s pretty damn good for everything else, too, unless you’re carrying +400 lbs of stuff >50% of the time.largely stock is good for a family road-tripper.
Great idea on the bump stops. I see a lot of FJ Cruiser/4Runner and '08+ LC references from Wheeler, but no 100 series listings. Does anyone have the exact part number?Have you thought about adding something like Timbren bump stops to the mix with the OEM shocks? They might assist with the compression over large bumps and stuff.
Thank you for the support. I fully intend to replace all the rubber components and will look into the tie rods/ball joints. I'll look into the various Dobinson shocks, but I have a couple final questions:
How light/thin are the OE Toyota TB in comparison to say OME or TD?
Would anyone recommend a set of Dobinson MRR under the stock setup or is it just overkill (and is there enough room)?
What is the best swap to minimize the prevalent factory body roll? (Simply a stiffer shock or does that lead into a full system swap?)
This is interesting, pretty easy install? Does the larger stop reduce any travel or does it just cushion it more?Good suggestion! Wheelers compared to OEM. Nice big and cushy. They sure smooth out dips and speed bumps.
Both are engaging at about the same time.
Easy to install. Just get the bolt started through bump head, then spin it on. On the first one I wrapped some tape on the bolt so it would not easily turn in the bump while so I could spin it on. Then finished tightening it up using the provided Allen wrench. If they reduce travel, I don't think its much.
I frequently do some hard wheeling over rocks. It definitely cushions the blow and makes the rig much easier to handle in ruff terrain conditions.
The Wheelers bumps made driving down "the steps" on Black Bear Pass easier on the driver and I'm sure on the rig.
Out of curiosity, what air bag system did you go with? I’ve heard the LC doesn’t work well with air bags due to rear flex and ripping. Anyone have experience with that?When I first got my land cruiser, I spent too much time researching the exact same thing you are asking about. Our LC is mostly stock, and we just use it for family road trips. It sits for weeks, and then we spend 99% of the trip on the road, with only mild offroading.
The SINGLE biggest upgrade I did was to add rear airbags. It would bottom out and wallow horribly, and I put those on and it made a world of difference. My overall suspension is cranked torsion bars and a 1" spacer in the rear, but the air bags make it infinitely tunable for whatever load we put in it. I run about 15 PSI and carry 7 people and their gear for road trips.
I am getting ready to redo the entire front with new ball joints, tie rods, bearings and brakes, but as far as suspension, largely stock is good for a family road-tripper.
