Suspension advice - no offroading or lift needed
Agree on doing suspension refresh first then figuring out what to do with tires.
One detail.. Note that it’s not necessarily the fact that they are all-terrains, it’s that most of them are offered in heavier-duty “LT-metric” aka Light Truck construction that kills ride quality. This is primarily because that heavy duty construction requires about 10psi more cold inflation pressure to safely support the same load, and the resulting increase in tire spring rate means much more of the “harnshess” or sharpness of road irregularities come through. This is on top of the stiffer sidewalls and extra mass, but I’ve played with tire pressure a lot. The difference between 33 and 42psi on the same tire is dramatic.
This means that you can absolutely get a road-oriented tire and end up with significantly worse ride quality, if it happens to be LT-metric.
Just check the sizing of any tire. If it has a LT in front of the aspect ratio (3-digit number), it’ll ride more harshly than the stock p-metric tires.
Sounds good! Thanks for that detail. BFG has new Trail Terrain tires which they say are for people who like KO2s but don't need them. I am definitely in that bucket. But again, I will do suspension first and then do tires and wheels little later. Still have some life left on the existing set.
