Hopefully someone has some experience on this.
So I replaced my brake lines with extended braided stainless steel lines as part of my recent lift. Fairly easy... did the brakes bleed RR, LSPV, LR, then LSPV again Just in case, then FR and FL.. Always kept fluid in the reservoir making sure it never ran dry. I used a hand pump self bleeder never exceeding 15LB pressure till I had no air coming out!
So to test drive.. I drive it 4-5 miles to pickup some materials for step #6 to congratulate myself on a job well done.. Brakes worked perfectly and at least felt better with the SS lines
came out of the store and the brake pedal is super hard, with no power on the brakes... !
Limped it home, recruited my neighbor to help me bleed the system again this time without the hand pump/bleeder and using the 2 man system.. no air in the lines.. and all is good.. Checked vacuum line to the booster.. all good.. Still Super hard brake pedal and no brakes!
Limped it to brakes+ bout a mile down the road for a "free" diagnostic.. And they tell me it's a vacuum problem from the engine! WTF??
Engine runs fine.. if it had no vacuum.. wouldn't the engine stumble or run like crud?
So I high tailed it out of there.. I knew I should never let any of those McBrakes places even look at my cruiser..
now I am back to the hive to look for wisdom!
