Sunroof in a 60?
Got-R-Did
Anyone seen this or done it? I am prolly going to be cutting into my roof to replace the winshield area (f***ing rust :mad: ) so I thought about doing this at the same time. Pics would be good if it's available. Thanks,
Todd
There could be some out there, but I haven't seen one.
I think it's either hard or impossible to do because the 60's roofs are corrugated.
Maybe someone else could chime in.
I have searched it- hoping for some fresh insight. I figured that the corrugated sections could be rewelded at the rear section of the roof. Easy by no means, but possible?
Todd
I was thinking about a full length ragtop from them too, though I would wait until I put some sort of roll cage in it first.
Someone did it...I swear...
I could have sworn I read a post from someone who had a "real" retractable sunroof in their 60. I can't remember if he bought it that way or not.
It may have been posted on the Cruizers.com board, although they cleaned the server a while back, I hope it wasn't deleted.
good luck with your search...
CardinalFJ60
like this? :D
This was installed by the PO of my '90 FJ62, in 1991. It is electric, retractable, tiltable. It has been leaking at the car wash recently, but before that it didn't leak at all. No leaks in hard rainstorms, only at the car wash under pressure.
The brand is ASC. I don't know if they are still available.
Yes!!
Ah-HA!! I knew it...I was even going to post that I thought it was Blue! That is one slick setup - tiltable and retractable. sweeet.
Thanks for the post and the pic!
CardinalFJ60
That's nice Yooper.
How did they deal with the undulations toward the back?
Maybe a little clear silicone under the gasket can take care of the little leaks.
Btw, is that where it's leaking?
As far as I can tell it's completely sealed up at the roof itself. It leaks around its own seal around the window - it leaks less if I tilt it and then close it than if I open it and then close it - I think I just need to adjust how tightly it closes or maybe get a new rubber seal - it is 14 years old after all.
I also have a factory sun roof in my HJ61... I don't have any pics and it snowed 12" last night so you're SOL for today!!
Any decent auto glass shop will install a C.R.Laurence "moonroof" in a 60 for $3-400 up. Best way to deal with the ridges ("undulations") is urethane adhesive (kit comes with butyl tape, but it's messy above 80 degrees). CRL also sells an electric version like the ASC, but it'll run you $4-500 more.
Back in the dark ages I worked with a stunning chick who drove a Camaro with T-tops that leaked. She said her father said "great - cut holes in a perfectly good roof!". This runs through my mind each time we install a sunroof.
