Well that title should help folks out using the search. My carpet was wet after a hard rain the other day, so i said darnit, guess the drain is clogged again. I did go wheelin' two weekends ago and got pretty muddy all over, including the roof.
Dug up some thin wire, fashoned a cloth to the end (think like a gun barrel cleaner) and eased it down the drain. Then i poured some water down the drain to see it drain out. I poured a good 16 oz. of water down the drain, and nothing. Plunged the wire and cloth down for another clean and hopefully dislodge the blockage. More water, a little trickle. Then i decided to pop the kick panel off and have a look. THis is what i found!
Note the areas circled in blue are very wet. Also circled are sources of drippage.
