- Thread starter
- #21
Aggressor pilot in the 38A, but previous F-15C pilot. Heading back to Texas for a teaching gig in 38’s!I want to know more about that day job? F-22, JSF or T-38? Or all three? Aerial photographer?
Might have to go that route...thanks!I have a 10/79 - happy to compare notes
Looks to be an inch lower on the drivers side but fairly symmetric front to back. Probably a leveler block is the easiest solution. I know man a fre sells a trim plate thats 1" used to preload the spring, but I'm unsure to what degree this 1" thickness translates to in height change.
Send me a message when you get it done! Would love to know. Thanks for chiming in.I too have the infamous cruiser lean on my ‘76, OME suspension and 33” BFG KM2s - my fender measurements are extremely similar to yours. I ordered the leveling block kit from CCOT recently and am planning to install in the next week or so, I’ll let you know how it goes!
I’ve read mixed reviews, but have seen enough cases of success when the lean is around 1” that I’m willing to risk $30 and some time wrenching. It’s not a huge deal like you mentioned, but it’s noticeable if you’re looking for it and enough to bug me too!
Wow, great to know and food for thought. Thanks!Hi, Our 1979 had a York a.c. We took it out . My mechanic installed them back in the day and said they used up about 22-23 hp! I do know It made a big difference when removed . Mike
1) Turns out this "1980" is really a Sep of 1979 build. I've been wrong this entire time!
I have a makeshift one in there right now. Waiting to put the OEM tank back in, but holding off until the washer pump motor gets delivered from @ToyotaMatt.What happened to your washer / coolant overflow tank? I see some kind of bracket attached to the passenger side of the radiator?
I’ll give it a check, thanks!Your description sounds like its the brake pads rattling in the calipers, especially when the noise goes away when you apply the brakes. Check your anti rattle clips on the brake pads.
