- Joined
- Nov 6, 2003
- Threads
- 25
- Messages
- 284
- Location
- Frankfort Ky
- Website
- www.threeelementsdesigns.com
Well, a quick background, I have had good oil pressure for 7 years or so, roughly around 14 lbs per 1000 rpm at operating temperature. Yesterday, I went to Slade, Ky, spending roughly 12 hours or so comuting and on the trails with little problems regarding oil. On the ride home, I noticed I was only getting around 20 psi at 2300 rpm, which seemed low, but the engine was working hard all day. When I pulled off the highway, my pressure dropped to zero, and before I could react and shut off the engine, it stalled on me. So, I started up the truck after letting it sit for 5 minutes, and pressure is zero at idle, but around 15 at 2000 rpm, so I left the truck. This morning I went back to tow her, but she fired right up like nothing ever happened, back with normal oil pressure, so I drove her home, and let her idle for a while, to make sure she got up to operating temps in both the coolant and oil. Works fine now, so what gives, is my pump on the fritz? I can't imagine an oil pump would take a break, and then start working again. What do you think? Thanks
