SUCCESS !! Toyota 86120-89118 radio (which prong is power *see picture) (1 Viewer)
Wadesters
Newnan, GA
Website
www.cwcruisers.com
I have the pictured radio. Trying not to blow it but test it. I know the two prongs are for power. Can anyone tell me which one is power and which is ground? I looked at cooler mans schematic and still could not tell. Thanks..
I don't recall specifically but I believe that with the radio in the off position you will have continuity to the chassis from only one of the two terminals. That one would be the ground.
The top T shaped connector is the power. All the old Panasonics I've seen had the negative or ground on the horizontal tab. A lot of times you will see a single connection to the vertical tab (+) and nothing on the horizontal tab since the radio is grounded by the mounting. Easy to verify with a meter as @cruiserdan stated. The bottom three terminals are speaker connections, the horizontal tab is common or ground.
If it is just 12volts and ground, only 2 tabs would be needed. Why 3 ?
The 3 prong is for the speakers.
I am 90% sure this is correct.
Don't hold me responsible, please.
Dyno
@Wadesters--so, to confirm, Dynosoar's photo of the connections is correct, including the speaker connections?
