Success reading AHC pressure, etc. w/ iOS app?
Boston
I've seen that many people have had success using a BT OBD reader + Android app to read AHC pressures, etc. ( ie. more than the basics) but has anyone had success using the OBD reader with an iOS app to get this level of data? I recognize the OBD needs to be WiFi instead of BT for iOS. Thanks!
MPLS
I started fiddling with OBD Fusion earlier this year that I run on an iPad in the truck. I modified two dashboards that some 200 series guys were using. One is for anything engine and transmission. The other is for AHC.
I need to look into it again to refresh my memory but it does read Accumulator Pressure, AHC oil temp and height sensor stats. I will check to see if it reads front and rear pressures.
I use a Veepeak BLE+ Bluetooth 4.0 OBD module. I wanted to still be able to hotspot from the iPad for data so BLE+ solved that comm issue.
Boston
That would be awesome. Thanks!
SoCal
Here’s some screenshots using Veepeak/OBD Fusion/iPad
Boston
Looks like the Front Pressure Sensor (mpa) and Rear is indeed what I'm looking for. Thanks!
long island NY
Did you ever find out what obd and app worked for the ahc globe pressures?
MPLS
Right in this thread above there are screenshots. OBD Fusion with a Veepeak adapter work. Choose the automatic height control suspension module when connecting. Then set up a dashboard pointed to the various items you want to monitor.
My dashboard needs work as I lifted one from the 200 series guys and started changing the fields but never finished.
