icorradoi
Hello, I'm installing a factory subtank into my 96 LC and have a couple of questions.
The tank I got from SWCruiser came out of a '92 1HZ Diesel cruiser from Down Under. So from what I've read it has two different components compared to a petrol tank.
1. The fuel pick up tube has an extra vent pipe coming out of it where the petrol version only has the fuel pick up tube coming out of the tank.
2. The fuel level sender has two wires coming out of it instead of the three found on the petrol sender.
So my questions are: Do I need to replace the pick up tube with the single pipe version or can I somehow just plug the extra vent tube or tie it into the EVAP system?
Can I use the Diesel level sender with George's ECU or will that sender not be compatible?
I tried to see if I could get the sender from my Toyota dealer, but they said that although Toyota had them in stock in Ontario, they would not sell them to me.
The pick up tube I cannot find anywhere. Maybe someone here can order it from a Toyota dealer overseas?
I believe the part numbers are:
77017-60300 Fuel Pick up Tube
83320-69215 Fuel Level Sender
Any help or advise is appreciated!
