subtank draining while using maintank lc100
Venezuela
Hi , I have a 100 series with Sub tank and lately my Subtank has been draining without being used , I ve taken down the check valve and cleaned it and its still using the gas even though im only using the main tank !
anyone knows a solution for this? thanks
No OEM sub-tanks in the USA. May have better luck getting a response in the OZ TLC forums.
It's a fairly common issue. There are two solenoids, a main and a return line. I'm guessing it's your main solenoid. The is the 80 series but I think it's the same set-up.
80 diesel sub tank info needed | IH8MUD Forum
Hello , thank you ! sorry for my ignorance , if the Solenoid was not working than it shouldn't be draining?
The solenoids are diverter valves. One input hose and two output hoses. Your aux tank seems to be feeding into the engine but the return going into the main. Check the solenoids and check the wiring to the solenoids.
thanks Ill check it out
