Sub tank plumbing questions.
Oregon
Are you guys also replacing the filler hose that goes into the top of the main tank?
Most of you added the T junction at the breather hose near the main tank. Would it also work if you put the T junction in the breather hose that comes off the filler neck?
It looks like rgsiii did it that way.
https://forum.ih8mud.com/showthread.php?t=104791
Thanks
I cut the breather tube that went from the hardline into the main tank. I then shortened both sections to fit my tee.
Ken,
Did you also replace the filler hose that goes from the hard line to the main tank?
A few more parts and I will be ready to finish this install.
Ken,
I bought the hose and used a cut down section between the hardline and the tee. The tank side was like glued on and access was crap. The hose condition seemed fine, so I cut that down and reused the side. I have a section of the hose I carry with me as a spare.
The hardest thing is finding a brass tee. I had to go to one of the old mom and pops hardware store and assemble a brass tee with 6 pieces of brass stuff. This made the length of the hose on both sides smaller and I had to cut some more off the hose after I first built it.
attachment.php
Excellent tip!
:beer:
