JUST TO DOUBLE CHECK.....
I rotated the pinion angle up to 14 degrees and tacked the perches.
If I sitting in front of the left (Driver side - long axle side), what should the needle read on the angle finder?
If 0 is center, should the needle be 5 to the left or to the right of 0? I assume to the left of the needle would be -5?
So essentially tilting the pinion angle to 14 degrees made the knuckles a positive 15? So I just need to turn them back 10 degrees or so, so that the needle is to the right of the 0, by 5.
The result - driver side - to the right of 0 by 5, and passenger side - to the left by 5 - so that in the end the knuckles are pointed or tilted 5 degrees "forward"? Or is it back?
Just need another eye here before I start welding.
ragman
ragman
